UC300-5LPT USB drivers wont install win 10 64
Re: UC300-5LPT USB drivers wont install win 10 64
Postby dezsoe » Tue Sep 14, 2021 5:59 pm
The same as you. Windows 10 Pro x64. The only difference is that I have Hungarian. You have to have the UC300 connected. You'll find the device down in the USB stuff. Here is the screenshot with the English text written in black:
Postby gabi68 » Tue Sep 14, 2021 9:02 pm
Yeah I understand that. My problem is the device does not have a driver because I cant install one. See capture
gabi68
Postby dezsoe » Tue Sep 14, 2021 10:13 pm
OK, I see. Just press uninstall and go on with the list I wrote.
Postby gabi68 » Tue Sep 14, 2021 10:25 pm
I tried that many times and is not working. I really need a solution for this.
On the other hand the ethernet device:
- I suppose that will not suffer from the M$ fuck up or am I dreaming?
- dimesions are the same like the USB controller (reason to ask is because I have that mounted in a box with the right holes)?
- can I send back the USB controller and have the ethernet one (paying the difference if there is one)?
Thank you
gabi68
Postby cncdrive » Wed Sep 15, 2021 3:44 am
Try to disable drivers signing enforcement in Windows and then the drivers will sure install.
The ethernet motion controllers are network devices, so they need no drivers.
Yes the dimensions are the same.
No, we do not take back old motion controllers, the UC300USB is no more manufactured several years now.
But again, in worst case you can install the USB drivers with disabling drivers signing enforcement in windows.
Postby gabi68 » Wed Sep 15, 2021 11:01 am
I tried all tricks found on internet to cheat windows about that driver signature (Startup trick, Testing mode, Group policy). None .of them worked. What else should I try?
gabi68
Postby cncdrive » Wed Sep 15, 2021 11:15 am
It works with driver signature enforcement disabled.
If it does not work for you then you did not disable it properly.
Postby gabi68 » Wed Sep 15, 2021 12:34 pm
I think you should look deeper. I try all and the capture is a proof and I am still not able to install the drivers. Any other advices?
gabi68
Postby gabi68 » Wed Sep 15, 2021 5:32 pm
Anybody....
gabi68
Postby cncdrive » Wed Sep 15, 2021 5:42 pm
Also try to disable the Secure boot option in the BIOS and after that turn the signature enforcement off and then disconnect from the internet and remove the drivers in the device manager (if anything is installed) with checking the Delete drivers checkbox and then try to install the drivers from location from the drivers file package.
