Estop problem with upgrade
Postby markcadcam » Wed Jun 12, 2019 12:44 pm
This morning I upgraded my software from 1.2046 to 1.2110. Now my Estop will only activate when the switch is normally closed, even if I change the setting 'Active low'. The setting 'Active low' makes no difference checked or unchecked. I move the Estop to another pin and it does the same thing. Was there a change made in version 1.2110 for the Estop to activate only when a switch is closed?
Mark
markcadcam
Re: Estop problem with upgrade
Postby markcadcam » Wed Jun 12, 2019 1:38 pm
A little more information. I'm using a UC300 (USB) controller with a 5LPT board. The Diagnostics shows everything is working properly.
markcadcam
Postby markcadcam » Thu Jun 13, 2019 1:45 am
Can I get some help please?
markcadcam
