Saving Points files
Re: Saving Points files
Postby cncdrive » Mon Jan 15, 2018 4:25 am
Yes, that field, the filename to save to is not editable and so the software does not accept the new value when set onscreen or via macro/plugin, in other words it will not update the internal variable which holds the filename, only if it is set with the SET button. I'll check what can I do about this issue.
