Minor issue with LED codes
Postby CNC22369 » Mon Sep 19, 2016 8:19 pm
The LED codes selection dialog window in the Output Trigger tab (press Set) lists LED codes 120-136 incorrectly. Instead of 4P in the Function Name and Description columns, it should be 5P. Please note that in the LEDs_by_number.htm file in the documentation directory the codes are correctly listed as 5P codes.
CNC22369
Re: Minor issue with LED codes
Postby cncdrive » Tue Sep 20, 2016 4:50 pm
Thank you Frank, I will look after this document error.
