New bug in 1.2041, or is it just my configuration?
Postby A_Camera » Tue Jun 27, 2017 7:28 pm
Hi Balázs,
It seems that the last position and the jog feed % is not saved after exit. This is new so I don't know why. My configuration is as before, yet when I exit UCCNC those are not saved. Am I doing something wrong or what happened? Maybe the new reset and save routine is the culprit, but it is strange that nobody else has seen this before if it is a general issue.
Re: New bug in 1.2041, or is it just my configuration?
Postby Derek » Tue Jun 27, 2017 8:17 pm
Somethings up for sure. I just ran the machine over to the limits in X,Y and Z. Shut dow and restarted and Y and Z are still the same but X is way off.
Derek
Postby A_Camera » Tue Jun 27, 2017 8:41 pm
Yes, that's what I am seeing as well. Also, in the jog panel if I change the feed rate percentage it is not saved when I shut down UCCNC. When I restart it is back to the old value. I think tomorrow I'll go back to 1.2039 again until I understand what is going on.
Postby cncdrive » Tue Jun 27, 2017 10:06 pm
Hi Guys,
Thank you for finding this issue, I verified and really the saving on the application closing does not happen, it is a new bug in version 1.2041 and it is because we reworked the saving routine to speed it up and what I see is that a part of the saving routine which actually flushes the data to the profile file missing from the Save on closing routine.
I now corrected this issue and uploaded the corrected exe to our server.
Here is the download link:
The exe works only with the test version 1.2041 UCCNC: http://www.cncdrive.com/UCCNC/UCCNC.exe
My tester collegue is now on holidays, otherwise he would sure find this issue before release, now it can be seen how important his job is.
Postby A_Camera » Wed Jun 28, 2017 6:54 am
Thank you very much. I will download and continue with that exe file later today afternoon.
Postby Derek » Wed Jun 28, 2017 11:37 am
That fixed it for me. Thanks
Derek
Postby cncdrive » Wed Jun 28, 2017 12:08 pm
OK, thanks guys.
Postby A_Camera » Wed Jun 28, 2017 4:32 pm
The positions are saved but the jog feed % in the jog panel not.
Postby cncdrive » Wed Jun 28, 2017 5:01 pm
The jog feed % was never saved by the UCCNC. It has to be something that you saving yourself if it was saved.
So, the question is how do you save the jog feed %? By a macro? By a plugin? Or how?
Postby A_Camera » Wed Jun 28, 2017 5:18 pm
OK, thanks. I was pretty sure it was saved before and not kept at the 10% where it otherwise seems to start. I have no macro for it yet, but will probably add one, or maybe add a line to the constructor macro to increase the default jogging speed from 10% to 30%.
Edit:
Just solved it by changing this line in the Defaultscreenset.ssf:
AS3jog.Setfieldtext("10", 913);
Changed 10 to 30 and now it starts with 30%...
