v1.2118 Modbus bug
Hi CNCDrive,
I recently started using a USB to RS485 adapter to control the spindle. Since I cannot understand yet how the modbusmaster plugin works I managed to make it work with the "ModbusEZ" plugin.
It works very well and reliably in version 1.2115. Just occasionally UCCNC would not connect to the USB adapter on starting up UCCNC but it gets quickly sorted by restarting UCCNC again and it would connect reliably again.
I know when it is working because as soon as UCCNC finish the startup "loading" screen the Tx light on the adapter starts blinking immediately (as per attached photo) independently if the VDF is powered on or off.
Now with version 1.2118 it randomly connects, theres is no real pattern for in what situations it would connect. If it does, if I close UCCNC and I open again it may work a second time but the 3rd time would not connect again. Sometimes restarting the PC or resetting the adapter appears to help but most of the time it doesn't. Also having the VFD on or off or the cable connected does not appear to make any difference either. I had a play with all the advance settings in the adapter driver (latency, buffers turning on and off legacy options, etc) and nothing appears to help unless I comeback to version 1.2115 so I think I narrowed it down to a UCCNC problem.
Any idea of what may be causing this?
