Comments in GCODE produce wrong tool start position
Postby andrewwong2000 » Fri Jan 08, 2021 4:46 am
This one confused me for a little while!
The following command and comment works fine:
N0080 M10.2 (Post AVC On) (Part: 20200107 - Tray 1-490)
but this line causes UCCNC to start at Y = 1490mm:
N0080 M10.2 (Post AVC On) (Part: 20200107 - Tray 1 490)
Please see the attached sample GCODE files.
The only difference is the "-" in the comment.
20200107 - 490 Tray1.tap
Works OK
(831 Bytes) Downloaded 427 times
20200107 - 490 Tray1 -bug.tap
Comment in file is interpreted as start from Y1490
(831 Bytes) Downloaded 424 times
andrewwong2000
Re: Comments in GCODE produce wrong tool start position
Postby dezsoe » Fri Jan 08, 2021 8:36 am
UCCNC does not like more comments in a line, the second comment is the problem.
Postby GaryLa » Sat Feb 20, 2021 1:50 pm
I have seen that as well. It seems to "find" commands to execute within the second comment.
GaryLa
Postby cncdrive » Sun Feb 21, 2021 7:29 am
Yes, thats true, the UCCNC really looks for the comment () only one time.
Honestly I did not think that multiple comments are placed by any CAM software, but I see now that it can happen.
So, we will fix this issue.
