Start Screen - minor bug or setting??
Postby trendsetter » Sun Nov 25, 2018 9:00 am
Hi all,
I am usung version 1.247 of UCCNC with 2017 screenset and when I start the Software the start screen is "Tools" but mixed up with with other items of different screens. When change to main screen, it runs again fine. Therefore just a minor issue.
Not sure, whether this is a bug or a setting. Can anyone help on that?
BR
Michael
trendsetter
Re: Start Screen - minor bug or setting??
Postby Robertspark » Sun Nov 25, 2018 10:09 am
Go to the edit screen button
When the with screen floating tab arrives, hold the ctrl key and use the mouse button to navigate to the main screen.
On the floating screen editing tab, press save screener, and exit screen editby closing the floating screen tab.
You can now restart uccnc and it should start on the home tab, it's because you pressed save on the screen edit while being on another tab, other than the main screener tab
Postby ger21 » Sun Nov 25, 2018 1:07 pm
What Rob said.
If you edit the screen, you need to go back to the Run tab before you save it.
Postby trendsetter » Sun Nov 25, 2018 2:56 pm
Hi all,
thanks, worked...
BR
Michael
trendsetter
