Combobox object issue (bug).
Postby kig23 » Thu Aug 16, 2018 2:43 pm
in the screen editor it's possible to change the font type of the combobox, but when you restart UCCNC the font of the combobox is always Arial. I see that in the function Addcombobox () is "missing" the parameter for font type. There are parameters for fontcolor, fontsize, etc. , but not for font type. Is there a way to change the font type of the combobox (for example combobox 4, 5, 6, 7, 8, 9)? Thanks
kig23
Re: Combobox object issue (bug).
Postby kig23 » Fri Aug 17, 2018 2:58 pm
I hope Balazs will answer this post. Thanks
kig23
Postby cncdrive » Fri Aug 17, 2018 3:13 pm
Sorry, I don't have time to check this out, I'm preparing for my summer holiday and before that I have to finish too many things.
I can check this out only in the beginning of September.
Postby kig23 » Fri Aug 17, 2018 3:20 pm
Sorry Balazs for disturbing. We'll talk about this when you come back at your holiday. Have a good holiday.
kig23
Postby kig23 » Tue Sep 04, 2018 8:29 am
Could you be so kind to check this issue. Thanks
kig23
Postby cncdrive » Tue Sep 04, 2018 9:35 am
Yes, I have checked and really the font type parameter is missing when it is saved and loaded to and from the screenset for the Comboboxes.
I will need some time, but will correct this issue.
Postby kig23 » Tue Sep 04, 2018 10:27 am
Thank you very much Balazs.
kig23
Postby cncdrive » Fri Sep 07, 2018 2:57 pm
No problem. :)
This is now fixed, it will be fine in the next test release.
Postby kig23 » Sat Sep 08, 2018 2:48 pm
Thanks indeed Balazs.
kig23
