Bugs in 1.2117
Re: Bugs in 1.2117
Postby cncdrive » Sun Feb 09, 2025 8:52 pm
Unfortunately we can't debug the HYPlugin, because it is a 3rd party plugin, we do not have the source code.
I would contact the author about the issue.
One thing is the the spindle acceleration parameter was changed in 1.2117 from rotation per second/second to time to rotate up/down from min. to max. RPM in seconds.
Maybe the plugin has problem with the new parameter.
Re: Bugs in 1.2117
Postby twedlake » Thu Feb 27, 2025 4:10 pm
cncdrive wrote:In 1.2117 spindle acceleration works differently, now you have to set the time for the acceleration, so you probably need to adjust the spindle acceleration parameter.
I have noticed this as well since moving to 1.2117 a few months back, but I have no clue what spindle acceleration parameter you are referring to. When the job is completed, it takes about 6+ seconds for spindle to turn off.
Would you mind explaining this with steps to correct this behavior for all us idiots out here that aren't good with programming UCCNC please sir and thanks!
or is it as simple as just changing this number to something like 2 or 3 from 10?
twedlake
Re: Bugs in 1.2117
Postby twedlake » Fri Feb 28, 2025 12:23 am
just had to think about it for a minute.. yes that did the trick.. thanks @cncdrive
twedlake
Users browsing this forum: Bing [Bot] and 5 guests
