"Run from here" does not dwell before movement
Postby berkenboom » Sat Jun 09, 2018 9:20 pm
Hallo, i am running a uc400eth with version 1.2047 and today i did a facing operation, where I needed to to pause and continue again.So i stopped the cycle when the mill was on the lower side about 50% in the program, did some jogging outside the stock (kept z-height) and pressed run from here.
Then i got the "initial movement preparation" dialogue, switch spindle on first was checked. but when i hit ok, the machine began to move and at the same time stared the spindle.
without dwell time, so the spindle was not up to speed yet.
I have the included the cnc file (small file 170 lines)
The weird thing is, i tested this in the demo and one time it did dwell correctly. :/
but mostly not, so i guess its a bug.
(T15  D=10. CR=0. - ZMIN=0. - flat end mill)
G90
(Face1)
T15 M6 (flat end mill D=10. ZZC 10mm ALU)
S6000 M3 100 Hertz
G64
G54
G43 H15
G0 X-60.779 Y-36.504
Z16.
Z6.
G1 Z3. F1800
Y-36.496 Z2.786
Y-36.474 Z2.573
Y-36.436 Z2.362
Y-36.383 Z2.155
Y-36.315 Z1.952
Y-36.233 Z1.754
Y-36.137 Z1.562
Y-36.028 Z1.378
Y-35.906 Z1.202
Y-35.771 Z1.035
Y-35.625 Z0.879
Y-35.469 Z0.733
Y-35.302 Z0.598
Y-35.126 Z0.476
Y-34.942 Z0.367
Y-34.75 Z0.271
Y-34.553 Z0.189
Y-34.349 Z0.122
Y-34.142 Z0.069
Y-33.931 Z0.031
Y-33.718 Z0.008
Y-33.504 Z0.
Y-28.229
Y24.771
G2 X-59.067 Y26.484 I1.713 J0.
X-57.354 Y24.771 I0. J-1.713
G1 Y-28.229
G3 X-55.641 Y-29.942 I1.713 J0.
X-53.928 Y-28.229 I0. J1.713
G1 Y24.771
G2 X-52.215 Y26.484 I1.713 J0.
X-50.502 Y24.771 I0. J-1.713
G1 Y-28.229
G3 X-48.789 Y-29.942 I1.713 J0.
X-47.076 Y-28.229 I0. J1.713
G1 Y24.771
G2 X-45.363 Y26.484 I1.713 J0.
X-43.65 Y24.771 I0. J-1.713
G1 Y-28.229
G3 X-41.938 Y-29.942 I1.713 J0.
X-40.225 Y-28.229 I0. J1.713
G1 Y24.771
G2 X-38.512 Y26.484 I1.713 J0.
X-36.799 Y24.771 I0. J-1.713
G1 Y-28.229
G3 X-35.086 Y-29.942 I1.713 J0.
X-33.373 Y-28.229 I0. J1.713
G1 Y24.771
G2 X-31.66 Y26.484 I1.713 J0.
X-29.947 Y24.771 I0. J-1.713
G1 Y-28.229
G3 X-28.234 Y-29.942 I1.713 J0.
X-26.522 Y-28.229 I0. J1.713
G1 Y24.771
G2 X-24.809 Y26.484 I1.713 J0.
X-23.096 Y24.771 I0. J-1.713
G1 Y-28.229
G3 X-21.383 Y-29.942 I1.713 J0.
X-19.67 Y-28.229 I0. J1.713
G1 Y24.771
G2 X-17.957 Y26.484 I1.713 J0.
X-16.244 Y24.771 I0. J-1.713
G1 Y-28.229
G3 X-14.531 Y-29.942 I1.713 J0.
X-12.818 Y-28.229 I0. J1.713
G1 Y24.771
G2 X-11.105 Y26.484 I1.713 J0.
X-9.393 Y24.771 I0. J-1.713
G1 Y-28.229
G3 X-7.68 Y-29.942 I1.713 J0.
X-5.967 Y-28.229 I0. J1.713
G1 Y24.771
G2 X-4.254 Y26.484 I1.713 J0.
X-2.541 Y24.771 I0. J-1.713
G1 Y-28.229
G3 X-0.828 Y-29.942 I1.713 J0.
X0.885 Y-28.229 I0. J1.713
G1 Y24.771
G2 X2.598 Y26.484 I1.713 J0.
X4.311 Y24.771 I0. J-1.713
G1 Y-28.229
G3 X6.023 Y-29.942 I1.713 J0.
X7.736 Y-28.229 I0. J1.713
G1 Y24.771
G2 X9.449 Y26.484 I1.713 J0.
X11.162 Y24.771 I0. J-1.713
G1 Y-28.229
G3 X12.875 Y-29.942 I1.713 J0.
X14.588 Y-28.229 I0. J1.713
G1 Y24.771
G2 X16.301 Y26.484 I1.713 J0.
X18.014 Y24.771 I0. J-1.713
G1 Y-28.229
G3 X19.727 Y-29.942 I1.713 J0.
X21.44 Y-28.229 I0. J1.713
G1 Y24.771
G2 X23.152 Y26.484 I1.713 J0.
X24.865 Y24.771 I0. J-1.713
G1 Y-28.229
G3 X26.578 Y-29.942 I1.713 J0.
X28.291 Y-28.229 I0. J1.713
G1 Y24.771
G2 X30.004 Y26.484 I1.713 J0.
X31.717 Y24.771 I0. J-1.713
G1 Y-28.229
G3 X33.43 Y-29.942 I1.713 J0.
X35.143 Y-28.229 I0. J1.713
G1 Y24.771
G2 X36.856 Y26.484 I1.713 J0.
X38.568 Y24.771 I0. J-1.713
G1 Y-28.229
G3 X40.281 Y-29.942 I1.713 J0.
X41.994 Y-28.229 I0. J1.713
G1 Y24.771
G2 X43.707 Y26.484 I1.713 J0.
X45.42 Y24.771 I0. J-1.713
G1 Y-28.229
G3 X47.133 Y-29.942 I1.713 J0.
X48.846 Y-28.229 I0. J1.713
G1 Y24.771
G2 X50.559 Y26.484 I1.713 J0.
X52.272 Y24.771 I0. J-1.713
G1 Y-28.229
G3 X53.985 Y-29.942 I1.713 J0.
X55.697 Y-28.229 I0. J1.713
G1 Y24.771
G2 X57.41 Y26.484 I1.713 J0.
X59.123 Y24.771 I0. J-1.713
G1 Y-28.229
G3 X60.836 Y-29.942 I1.713 J0.
X62.549 Y-28.229 I0. J1.713
G1 Y24.771
G2 X64.262 Y26.484 I1.713 J0.
X65.975 Y24.771 I0. J-1.713
G1 Y-28.229
Y-28.443 Z0.008
Y-28.656 Z0.031
Y-28.866 Z0.069
Y-29.074 Z0.122
Y-29.277 Z0.189
Y-29.475 Z0.271
Y-29.666 Z0.367
Y-29.851 Z0.476
Y-30.027 Z0.598
Y-30.193 Z0.733
Y-30.35 Z0.879
Y-30.496 Z1.035
Y-30.63 Z1.202
Y-30.752 Z1.378
Y-30.862 Z1.562
Y-30.958 Z1.754
Y-31.04 Z1.952
Y-31.107 Z2.155
Y-31.16 Z2.362
Y-31.198 Z2.573
Y-31.221 Z2.786
Y-31.229 Z3.
G0 Z16.
M5
M30
berkenboom
Re: "Run from here" does not dwell before movement
Postby Vmax549 » Sat Jun 09, 2018 10:01 pm
Do you have a M3 dwell setup in spindle config ? That is teh only way to get a dwell on spindle startup working with the RFH function.
(;-) TP
Vmax549
Postby Derek » Sun Jun 10, 2018 1:45 am
Even with dwell on it fires up the spindle and makes its initial move. I've gotten used to it and I make sure I'm at max Z height before I hit run and I back it up enough lines to make certain I'm in already carved area.
So it is a thing for sure.
Derek
Postby Vmax549 » Sun Jun 10, 2018 4:04 am
Interesting. I just tested it again and it dwells ok according to teh Config value here.
I'll Test it some more, (;-) TP
Vmax549
