1.2109_Write Offset for Homing
Postby RWC » Sat Mar 23, 2019 1:30 am
Hi folks. :)
1.2109 Demo mode.
Configuration / Axis setup / Write Offset on Homing
The default download had X-0, Y-0, Z-2
I went to change the Z to 0 and it will not take. (hitting ENTER, of course).
I can enter any value other than 0 and it sticks in every axis but then trying to enter 0 in any of them, it reverts back to whatever the previous entry was. I now cannot get any axis Offset back to zero.
Is this a DEMO limitation ? or a possible BUG ?
Thanks for looking,
Russ
RWC
Re: 1.2109_Write Offset for Homing
Postby ger21 » Sat Mar 23, 2019 1:36 am
Works fine here, also in demo mode. Tried with UC100 Demo and AXBB demo.
Postby ger21 » Sat Mar 23, 2019 1:37 am
FYI, you can disable the "ENTER" key requirement on the Appearance tab, if you so desire.
Postby RWC » Sat Mar 23, 2019 1:41 am
ger21 wrote:FYI, you can disable the "ENTER" key requirement on the Appearance tab, if you so desire.
Didn't notice that ..... (yet) :) THANKS !
Forgot to mention, AXBB her aas well.
Strange.
I'll try it with the ENTER disabled ... FWIW.
Thanks Gerry,
Russ
RWC
Postby ger21 » Sat Mar 23, 2019 1:43 am
Are you clicking Apply Settings or Save Settings?
Postby RWC » Sat Mar 23, 2019 1:53 am
Yeah, I figured it out. Its a mini keyboard with the num pad overlying the qwerty keys.
With num lock on, 7,8,and 9 are the same but 0 is then an asterisk. Jeeeesh.
Turned the NUM LOCK off and its OK.
Thanks for taking the time Gerry, sorry.
Russ
RWC
Postby ger21 » Sat Mar 23, 2019 2:09 am
I was going to say bad keyboard, but that was too easy, lol.
