Mach3 - rigid tapping and multipass
Postby Olivier-CNC » Mon Apr 21, 2025 10:15 am
I have two questions for rigid tapping with Mach3 :
1) Using this Rigid tapping macro :
SetUserDRO(1200, Param1())   'P parameter = Z end
SetUserDRO(1201, Param2())   'Q parameter = pitch
NotifyPlugins(10200)      'Load parameter
SetUserDRO(1202, 0)         'Start Rigid tapping
While(GetUserDRO(1202) = 0)   'Wait for finish rigid tapping
   Sleep(50)
   NotifyPlugins(10201)
Wend
How to do multipass tapping ? is there a third hidden R parameter for multipass ?
Or do i need to implement multipass myself in the macro ?
2) How is managed M3 and M4 commands ? Are they sent automatically from the plugin ?
Thanks for helping.
Olivier-CNC
Re: Mach3 - rigid tapping and multipass
Postby cncdrive » Wed Apr 23, 2025 8:12 pm
Multipass is not implemented in that macro, you have to implement it yourself.
Or you can try UCCNC, it can do rigid tapping with multi passes.
Postby Olivier-CNC » Thu Apr 24, 2025 10:00 am
Thanks.
Spindle direction and control is not clear for me. I have two questions here :
1) How to choose CW or CCW tapping ?
Do we need to start the spindle with M3 or M4 before calling the NotifyPlugins(10200) function ? Then the plugin reverse direction at Zend ?
2) Is it possible to change spindle speed for retracts ? For retracts, it is common to choose a faster spindle speed to save time, 4 times faster is a common value.
Here is a Rigid Tapping macro i wrote with R parameter for multipass tapping. Let me know if i'm right. To test this macro i disabled the plugin code, because my spindle encoder is not yet ready to test that on the machine. Then it is not fully tested yet.
If someone can test it i would be interested to know the results.
There is some code inside to avoid running the macro if another one was running before. This is a protection i use inside my macros to limit crashes if another macro did not end correctly. This is especially useful during testing to check that there is no runaway macros.
Option Explicit
Const RunningMacroLED = 1242 ' Modify according to screenset
Sub Main()
'Rigid Tapping Macro - CNCDrive - Olivier ADLER 2025
'Q parameter = pitch (positive number)
'P & Q parameters must be specified for each successive tapping
'R parameter = pass depth for multipass tapping (must be a positive number)
'R parameter is permanent until mach3 restart (does not need to be specified for each succesive tapping)
'Use R0 to set back single pass tapping
'//////// Variables
Dim Multipass, MultipassDepth, Zend, Z_Axis_Pos, ZDepth, OtherMacroRunning
'//////// Pre processing
Message "" 'Clear message line
If GetUserLED(RunningMacroLED) Then 'If User LED 1242 is on, another macro is runing, take measures
   If Question ("Another macro is running, enter 1 to force execution") = 0 Then
      If Question ("Enter 1 to clear the macro runnning LED") = 1 Then
         SetUserLED(RunningMacroLED,0) 'Clear the macro runnning indicator LED
      End If
      Message "Another macro is running, exiting !"
      Exit Sub
   End If
   OtherMacroRunning = 1
End If
If param2() <= 0 Then 'if Q parameter is not a positive value then exit macro
   MsgBox ("Parameter Q must be a positive value, exiting macro")
   Exit Sub
End If
If param1() = -1 Then 'P parameter is probably not defined, ask and exit macro (-1 value is the default for unset parameters)
   If Question ("Enter 1 to confirm P : Z end = -1, or 0 to exit macro") = 0 Then
      Exit Sub
   End If
End If
Z_Axis_Pos = GetOEMDRO(186)
If param1() > (Z_Axis_Pos - param2())  Then 'Zend is higher than Z axis position or thread with less than one turn, exit macro
MsgBox ("Zend is higher than Z axis position or thread with less than one turn, exit macro")
      Exit Sub
End If
If param3() > 0 Then 'If R parameter is defined then enable multipass mode
   Multipass = 1
   MultipassDepth = param3()
   Message "Multipass Tapping"
End If
SetUserLED(RunningMacroLED,1) 'Enable the macro runnning indicator LED
'//////// Processing
If Multipass = 0 Then
   Sleep (250) 'Could be necessary
      Sleep(50)
   Wend
Else 'Multipass Tapping
   Zend = Param1() 'P parameter = Z end
   ZDepth = Z_Axis_Pos - MultipassDepth
   If ZDepth < Zend Then
      ZDepth = Zend
   End If
   'SetUserDRO(1201, Param2())   'Q parameter = pitch
   Do
      SetUserDRO(1200, ZDepth)   'P parameter = pitch
         Sleep(50)
      Wend
      Sleep(250)
      'MsgBox ("ZDepth= " & ZDepth)
      If ZDepth <= (Zend + 0.0001) Then
         Exit Do
      End If
      ZDepth = ZDepth - MultipassDepth
         ZDepth = Zend
      End If
   Loop While(ZDepth >= Zend)
End If
Sleep (250)
MsgBox ("P =" & param1() & " Q =" & param2() & " R =" & param3() & " Multipass =" & Multipass)
'//////// Post Processing
If OtherMacroRunning = 0 Then
   SetUserLED(RunningMacroLED,0) 'Disable the macro runnning indicator LED
Else
   If Question ("Another macro was running, enter 1 to clear the macro runnning LED") = 1 Then
   End If
End If
End Sub 'End Main Sub
Olivier-CNC
Return to Mach3/4 Discussions
