uc 100 Threading on mach3
Postby erdem55 » Sun May 07, 2023 1:23 pm
Hi Guys,
I bought an uc100 and use on mach3 that is stable.
,but Mach 3 threading is not stable that change pitch (step screw) .For example, I setup g76 1.814mm pitch ,but front of screw is 1.4mm ,the middle is 1.814mm ,the end is 1.4 or 1.2 mm.Diameter is 20.995 mm .(Pipe screw)
How do I solute that problem?
erdem55
Re: uc 100 Threading on mach3
Postby ger21 » Sun May 07, 2023 5:42 pm
Threading on Mach3 is very buggy in most Mach3 versions, and when not using a parallel port.
Postby erdem55 » Mon May 08, 2023 12:37 pm
ger21 wrote:Threading on Mach3 is very buggy in most Mach3 versions, and when not using a parallel port.
ok,nice
But how do I solve that problem?
erdem55
Return to Mach3/4 Discussions
