Apparently Artsoft don't know UCNC hardware exists !
I contacted them regards the losing input output fields issue and they carefully explained it to me as follows;
" Hello,
You have a motion controller.
We make software.
Your motion controller company said "Hey we could sell more controllers if ours worked with MACH4"
THEY made a motion controller plugin file so that it works with MACH4
We updated our software at some point after they made the plugin.
The plugin THEY made, is now broken because it's meant for an older version of MACH4.
If you're losing your configuration it's because the plugin version, and version of MACH aren't compatible."
Trevor
support@machsupport.comSo I guess UCNC are advertising UC300ETH is compatible to MACH but not staying up to date with Mach updates as ESS and other hardware suppliers are.
We are on our own on this mess.
