Routing with mach 3, Z goes deeper in every part
Postby Mazam » Mon Oct 09, 2023 6:24 pm
Newbie here.
Been routing with Victor cnc router for 3 years now with no major broblems until now. I noticed, when routing 3mm aluminium that after every holding tab and when changing to new part it cuts deeper and deeper.
I'm using Mach 3 and hicon.
When it goes deep it shows the correct (too deep) depht in mach 3 screen and after stop, when checking, the top of the aluminium plate is right at 0.
The g code seems to be correct and when checked with camotics it works just fine.
Can faulty step motor do this? I would think if the motor in Z axis would be losing steps it would not show the changed depht in mach 3..
What am i missing?
Thanks.
Mazam
Re: Routing with mach 3, Z goes deeper in every part
Postby ger21 » Mon Oct 09, 2023 6:41 pm
Yes, sounds like the Z axis is losing steps.
Postby Mac Designs » Sun Sep 01, 2024 12:16 am
Did you find the problem. I have a similar issue.
Mac Designs
Postby cncdrive » Tue Sep 03, 2024 12:00 pm
Check if the direction signal is configured properly. (Active low" setting.
If it is configured opposite then the drive could loose steps at every direction change.
Return to Mach3/4 Discussions
