Wizard Plugin
Posted: Mon Jan 15, 2018 6:27 pm
Hello All,
Following Vmax549 leads and recommendations I put together a Wizard that includes 4 for now, will combine cut and pocket a circle at some point. I tried to copy the wizard menu and wizard types we all got use to like in Mach3.
1. Cut a Circle
2. Pocket a Circle
3. Bolt Pattern with canned cycle's
4. Cut and Pocket a square/rectangle with editable/type corners.
What I'm hoping for is some help in testing, I want to be certain of no bugs so don't have to many different versions floating around like I've done in past. If anyone is kind enough or interested in helping please PM your Email and I will send.
Below is pics of some of the interfaces with samples.
Wizard Menu
Hole Pattern
Square/rectangle cut or pocket
1. Cut a Circle
2. Pocket a Circle
Wizard Menu
Hole Pattern
