Probe Gage Height not respected after switching to 1.2117
Postby Dale » Sat Mar 22, 2025 4:40 pm
I loaded ver 1.2117 and now I cannot use my M31 macro to probe surface of my workpiece.
It probes just fine, but it no longer adjusts the z offset. Lost an end mill and project as a result.
Here is my M31 macro.
Any idea what's changed from 1.2113 and 1.2117 that renders this macro useless?
M31.txt
(2.26 KiB) Downloaded 251 times
Dale
Re: Probe Gage Height not respected after switching to 1.211
Postby Carboncnc » Wed Apr 16, 2025 8:54 am
I think you have the same problem as I do. In the previous versions when probing Z (tool length) you didnt need to activate/deactivate "count guage height (or whatever the name is)" so I always do it wrong, that makes endmills break and projects scrapped !
And in my opinion its a bit random, but I can be wrong here, one thing is sure and that is the frustration....
Carboncnc
Postby sabrina23 » Thu Apr 17, 2025 4:27 am
Incredibox Hey Dale, have you tried comparing the output logs or release notes between version 1.2113 and 1.2117? I'm wondering if there's a change in the way the software handles macros or system variables that causes the G92, G10 command line, or Z offset update to not work as before?
sabrina23
