Page 2 of 2
Re: start/stop motion when cutting curves
Posted:
Mon Oct 16, 2023 8:32 pm
by jonathanmahnken
Thanks. The arc was drawn in vectric, so i don't know why I would need to convert my arc to an arc. I noticed that there is an arc tolerance setting in uccnc that is default set to .10. Im wondering if I need to adjust that to a much smaller tolerrance??
Posted:
Tue Oct 17, 2023 10:33 am
by Battwell
in vectric. click on the questionable curve.
select node edit . shortcut N on keyboard.
does the curve have hundreds of nodes or just a few per curve?
if loads-convert to curves.
if just a few- adjust your cv settings to a higher tolerance.
i had a rare job recenty that my cv settings were way too tight to run. adjusted and run sweet.
Posted:
Wed Oct 18, 2023 5:21 pm
by jonathanmahnken
Thanks. would a CV tolerance of .02" be to small? The factory setting was .10"
Posted:
Wed Oct 18, 2023 6:11 pm
by dezsoe
The factory settings are in metric, so if you use inches then you have to convert them first:
- Imperial.png (19.77 KiB) Viewed 1083 times
Posted:
Sat Oct 21, 2023 4:40 pm
by jonathanmahnken
Thanks this makes sense
