UC400ETH + USBB Mach4
Postby wmgeorge » Thu Feb 02, 2023 2:55 pm
Changing over to the above configuration IS the documentation on the USBB correct? Last time I used the UC400 it was a easy switch over. Now pulling what's left of my hair out. I have the + Dir and + Pulse going to +5 vdc like the diagram and the minus - going to the for example 2 & 3, nothing happens. Going out again today to check again. Is it normal for Red output LEDs to be on?? Yes the Port and Pins are set,
wmgeorge
Re: UC400ETH + USBB Mach4
Postby wmgeorge » Thu Feb 02, 2023 5:16 pm
OK Once again No Edit? I set the KHz from the default of 400 down to 25 KHz and its working. Now getting Mach4 setup.
wmgeorge
Users browsing this forum: Google [Bot] and 26 guests
