JIT enable option?
JIT enable option?
Postby Mario Soto » Thu Nov 28, 2019 11:42 pm
Hello.
After creating a profile with its own screen set, I can no longer make changes.
I get an "Unhandled exception" error with a detail tab.
The details are about 200 lines long which would mean nothing to 99.99% of the people who read it.
At the end, it says "When JIT debugging is enabled, blah blah blah...".
It doesn't say how to fix the problem and I don't see the JIT enabler option.
Any help would be appreciated.
Mario Soto
Re: JIT enable option?
Postby dezsoe » Fri Nov 29, 2019 6:22 am
At the top of this long blah blah blah there is an error message. What is that?
Postby Mario Soto » Fri Nov 29, 2019 1:50 pm
Unhandled exception has occurred in your application.
If you click Continue the application will ignore this error and attempt to continue. If you click Quit, it will close immediately.
Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index.
See the end of message for details on invoking just in time debugging instead of dialog box.
******** Exception Text *****
Blah blah blah..
Mario Soto
Postby Mario Soto » Fri Nov 29, 2019 1:52 pm
Thank you for your reply. If you need the whole text please ask.
I can not copy/paste it.
Mario Soto
Postby dezsoe » Fri Nov 29, 2019 4:15 pm
Yes, the top of the exception text is the error message.
Postby Mario Soto » Fri Nov 29, 2019 4:30 pm
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at System.ThrowHelper.ThrowArgumentOutOfRangeException()
at UCCNC.GUI.Leavetextfieldswithoutvalidation()
at UCCNC.GUI.gl_main_mousedown(Object , MouseEventArgs )
at UCCNC.Form1.glControl2_MouseDown(Object , MouseEventArgs )
at System.Windows.Forms.Control.OnMouseDown(MouseEventArgs e)
at System.Windows.Forms.UserControl.OnMouseDown(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.UserControl.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.9148 (WinRelRS6.050727-9100)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
UCCNC
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/UCCNC/UCCNC.exe
Win32 Version: 2.0.50727.9136 (WinRelRS6.050727-9100)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.9147 (WinRelRS6.050727-9100)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
OpenTK
Assembly Version: 1.1.0.0
Win32 Version: 1.1.1664.6217
CodeBase: file:///C:/UCCNC/OpenTK.DLL
疮퀐㣚븫귘_媰
Assembly Version: 0.0.65535.65535
OpenTK.GLControl
CodeBase: file:///C:/UCCNC/OpenTK.GLControl.DLL
OpenTK.Compatibility
CodeBase: file:///C:/UCCNC/OpenTK.Compatibility.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
ILCalc
Assembly Version: 0.9.7.5
dgjf3sit
Assembly Version: 0.0.0.0
Plugininterface
CodeBase: file:///C:/UCCNC/Plugininterface.DLL
AutoLevelerCA
CodeBase: file:///C:/UCCNC/Plugins/AutoLevelerCA.dll
Debugger
CodeBase: file:///C:/UCCNC/Plugins/Debugger.dll
Diagnostics
CodeBase: file:///C:/UCCNC/Plugins/Diagnostics.dll
Laserengrave
CodeBase: file:///C:/UCCNC/Plugins/Laserengrave.dll
Modbusmaster
CodeBase: file:///C:/UCCNC/Plugins/Modbusmaster.dll
Plugintest
CodeBase: file:///C:/UCCNC/Plugins/Plugintest.dll
Printer3D
CodeBase: file:///C:/UCCNC/Plugins/Printer3D.dll
Scope
CodeBase: file:///C:/UCCNC/Plugins/Scope.dll
UCCNC_OSK
Assembly Version: 1.7.3.0
Win32 Version: 1.7.3.0
CodeBase: file:///C:/UCCNC/Plugins/UCCNC_OSK.dll
UCR200Plugin
CodeBase: file:///C:/UCCNC/Plugins/UCR200Plugin.dll
UCR201Plugin
CodeBase: file:///C:/UCCNC/Plugins/UCR201Plugin.dll
Webcamera
CodeBase: file:///C:/UCCNC/Plugins/Webcamera.dll
Xbox360controller
CodeBase: file:///C:/UCCNC/Plugins/Xbox360controller.dll
XHC-HB04_pendant
CodeBase: file:///C:/UCCNC/Plugins/XHC-HB04_pendant.dll
qhnhodh3
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Mario Soto
Postby Robertspark » Fri Nov 29, 2019 8:18 pm
There is your problem.....
Rob
UCCNC v1.2110 Macro Manual
Postby Mario Soto » Sat Nov 30, 2019 12:06 am
No, half-baked software is the problem. I, Sir, am a victim.
Mario Soto
Postby beefy » Sat Nov 30, 2019 6:33 am
Mario Soto wrote:No, half-baked software is the problem.
Are you referring to UCCNC ?
Just making sure we understand you.
beefy
Postby Robertspark » Sat Nov 30, 2019 7:46 am
That there is your problem:
Mario Soto wrote: After creating a profile with its own screen set, I can no longer make changes.
If you post your profile (pro) and screener (ssf) files someone may be able to help.
I suspect you have modified a big chunk of code that was working perfectly well and now it does not work....
Rob
