Z axis stalling when set to over 80%
Posted:
Sat Apr 27, 2019 9:55 pm
by albatros3d
Recently I am having trouble with my Z axis which is stalling when I run it manually over 80%.
Not sure why it happened only on Z axis.
Any ideas?
Re: Z axis stalling when set to over 80%
Posted:
Sun Apr 28, 2019 1:07 am
by Greolt
You don't say if this is plasma THC or a router style Z axis.
The first thing I would be looking very carefully at, is mechanical changes. Binding etc.
Posted:
Sun Apr 28, 2019 5:08 pm
by albatros3d
This is a 3 axis cnc router. I disconnected the couple in order to eliminate any mechanical interference, same problem. Looks like has to do with acceleration.
Posted:
Sun Apr 28, 2019 5:40 pm
by ger21
If it used to work fine, then something has changed. Often it's a mechanical issue, or lack of lubrication. But it could be any number of other issues.
Lowering the acceleration will help mask the problem, but it doesn't fix it.
Posted:
Sun Apr 28, 2019 5:49 pm
by albatros3d
But since I have eliminated all the mechanical side by decoupling the stepper than mechanical issues even if they are will not effect the stalling.
Looks like something is in the electronics. I am using UC100. Both lights blue and green are on and the X and Y axis are working fine
Posted:
Sun Apr 28, 2019 7:20 pm
by ger21
Wire the Z axis motor to a different drive, and see if anything changes.
