Midi not working correctly
Postby Delco » Mon Apr 22, 2019 8:25 am
Something has changed on my setup and i cant work out why .
When a program is loaded it runs fine , first command is g0x0y0 which sends it to the zero position .
If i type g0x0y0 into the midi the machine moves a few mm and stops . I cant move to anyposition such as y100 it just moves a few mm and stops ????
Any ideas?, prior to this i could type x64 and it would move there so donething mudt have changed ?
Using the latest prerelease with a axxb-e
Delco
Re: Midi not working correctly
Postby ger21 » Mon Apr 22, 2019 10:54 am
What position (on the DRO's) is it stopping at?
Re: Mdi not working correctly
Postby Delco » Mon Apr 22, 2019 11:32 pm
Any position , start machine up , run homing cycle and then I normally select the coordinate system say g54 on the screen , then I normally issue a g0x0y0 on the mdi to go back to the last position saved (BTW DRO is not showing zero for G54 only machine coordinates) .
It used to work fine the only change I made to machine was to configure hotkeys for a num pad to drive jogging.
https://www.youtube.com/watch?v=S2HSK2XFfh8
Delco
Postby dezsoe » Tue Apr 23, 2019 5:18 am
What hotkeys did you define? Watching your video I see that any time you type something in the MDI then a stop message appears in the status box. Maybe, you have defined stop on the enter key? Make a photo of the hotkey settings and show us.
Postby Delco » Tue Apr 23, 2019 8:44 am
:D I think you are right , i did set cycle stop as the num pad enter key .
Delco
