The canned cycles are in the same modal as the G1,G2,G3 and this is where the problem comes from, that G80 is also in that modal and we did not think about making an exception of the G93 feedrate rule for the G80, but I will make that exception now.
I will check it, I think it should work. Meanwhile can you please post the g-code file with which you can reproduce this issue? And also tell me at around what part of the g-code do we have to change the FRO? (If it counts at all)
OK, I have checked with random code and could not reproduce it, the FRO works fine here with G93. So, please upload your g-code file and also your profile file.
