UCR201 USB wireless pendant
Re: UCR201 USB wireless pendant
Postby cncdrive » Sat Feb 23, 2019 10:13 pm
You have already posted your profile and my collegue (dezsoe on the forum) already gave you an advice, but appearantly you did not see that or at least you did not respond to his advice.
I'm saying that you will likely to have issues with HID installations, because if installing a HID device like the UCR201 kills/inhibits another HID device which is your spindle adapter then it is a serious problem in your Windows.
From your description of the problem this is what have happened.
Postby Gene8522 » Sat Feb 23, 2019 10:21 pm
[quote="cncdrive"]You have already posted your profile and my collegue (dezsoe on the forum) already gave you an advice, but apparently you did not see that or at least you did not respond to his advice.
I did follow dezsoe advice. and there was no change that I observed.
Please ask Balazs Klincsik for a copy of the e-mail i sent about a hour ago.
Gene8522
Postby cncdrive » Sat Feb 23, 2019 10:29 pm
OK, then we don't know what the problem is, sorry, but I see no logical reason other than somekind of Windows corruption, maybe you should just return the device and use something else if it does not work well for you.
Just contact our sales to return it, they will then reply you on Monday and will take care of it.
Ask for what information exactly?
Postby Gene8522 » Sun Feb 24, 2019 5:18 pm
The e-mail to Balazs Klincsik was to ask about returning the unit,
Gene8522
Postby cncdrive » Sun Feb 24, 2019 5:32 pm
Ahh, ok I see, that is the same what I adviced you, to return it if you can't use it, so what information sould I ask about that? I don't understand what you requesting from me, sorry.
Postby Gene8522 » Mon Feb 25, 2019 2:19 am
Hi Mr cncdrive,
I owe you an apology. No a big apology!
I have an XHC WHB04B pendant that I could never get to work with UCCNC. It works using Mach3 but I was never able to get it to work with UCCNC. Anyway I thought I would give it one more go in UCCNC.
While trying to setup UCCNC I saw that the spindle would not start, And while looking through the plugin setting again in UCCNC I saw that the plugin HYPLUGIN12 was not enabled.
I thought well.....maybe?
I enabled the UCR201 pendant plugin, plugged in the USB, restarted UCCNC 2017 Screenset........ Guess what? Everything looks to be working with the pendant. :D
Now if you could tell me how to set the 'F1, F2, and F3' to control the X, Y, & Z DROs? I would be a happy camper. :roll:
I'm sorry for any problems I may have caused. :oops: :oops:
AND THINKS FOR YOUR HELP! without these forums I would never have a working diy CNC
Gene8522
Postby dezsoe » Mon Feb 25, 2019 6:25 am
You have to enter the buttoncodes 220 to 222 into the plugin. (See Documentation\Buttons_by_number.htm for the buttonnumbers.)
Postby PillyWilly » Sat Mar 09, 2019 4:10 pm
Hi
Is cncdrive looking into the issues with this plugin.
It is frustrating to have spent quite a lot of Monet on a useless pendant.
Regards
Jan
PillyWilly
Postby Robertspark » Sat Mar 09, 2019 4:36 pm
What issues are YOU experiencing?
There appear to be no posts from you in this thread, and looking at the previous posts just before your post the issues were user error
