dezsoe wrote:
Gerry, I remember that you made some changes to some macros. Is it possible that they run some older version than me? Do you have the old versions of the changed macros that I should also test?
cncdrive wrote:OK, did you try to use a different USB port? Maybe there is a problem with the port if you have to unplug it means that the port chipset is likely frozen or in other words it gave up the connection for some reason.
