cncdrive wrote:It is the file with the .pro extension in the UCCNC/Profiles folder. The filename is the name of the profile you running in the UCCNC. The default ones are the Default.pro and the Plasma.pro.
cncdrive wrote:And you can't kill it in the Windows task manager?
Gene8522 wrote:cncdrive wrote:And you can't kill it in the Windows task manager?
NO that dosen't work...........
dezsoe wrote:Thank you for the profiles. Do you have an XHC pendant also connected? Did you try to disable the XHC plugin and then enable the UCR201? I'm asking, because the XHC plugin is enabled in your 2017 profile and I'm afraid that the two pendant plugins want to do the same controls.
