Huanyang VFD plugin
Re: Huanyang VFD plugin
Postby Gene8522 » Wed Aug 15, 2018 4:18 pm
Hi Gerry,
Just one more question.
Using 2010 screenset Mach3, I have control over the cooling on the spindle. It starts and stops when the spindle starts.
Using 2017 I can only get the cooling running all the time. Where should I look to setup the cooling for the spindle?
Gene8522
Postby ger21 » Wed Aug 15, 2018 4:43 pm
You'd need to tell me how you are doing it in Mach3. Are you using M7 or M8?
Whatever you are doing in Mach3, it would basically be the same in UCCNC.
This has nothing to do with the screenset.
Postby Gene8522 » Wed Aug 15, 2018 6:02 pm
Under the PWM Spindle I had to put a pin & port number. So now the cooling starts when the spindle starts. :D :D
Thanks for your help. I'm sure I have a working UCCNC 2017 Screenset. :D :D
Gene8522
Postby ger21 » Wed Aug 15, 2018 6:06 pm
So, somehow your machine is using the PWM signal to start and stop the coolant? Not how it's usually done.
Postby Gene8522 » Wed Aug 15, 2018 6:49 pm
I tried using the M7-M8 but could not get them to turn the cooling No or Off without a manual input or an M7 in the gcode. :roll:
But this PWM setup does work.
Gene8522
Postby merlinogio » Fri Sep 21, 2018 5:41 pm
Hi Dan, Ger
HY12 work when it have a good day..:)
screenset 2017
Hy12 configured as in instruction
Spindle talker go well (open port and go with the slider don't go with the Fixed RPM button 6000, 8000, etc)
when i open UCNC he talk with VFD that aswer (see below)
BUT
when i click M3 Nothing
sometimes it go but with fix RPM (don't change with s command)
any suggestion?
thanks in advance
flavio
Porta aperta dal processo "UCCNC.exe" (PID: 4056)
Richiesta:21/09/2018 18:41:24.38664
01 01 03 8E 00 00 5C 65 ...?..\e
Risposta:21/09/2018 18:41:24.40764 (+0.0210 seconds)
01 01 03 8E 00 64 5D 8E ...?.d]?
Richiesta:21/09/2018 18:41:25.17764 (+0.7620 seconds)
Risposta:21/09/2018 18:41:25.19664 (+0.0190 seconds)
Richiesta:21/09/2018 18:41:26.96764 (+0.7630 seconds)
Risposta:21/09/2018 18:41:26.98664 (+0.0190 seconds)
merlinogio
Postby ger21 » Fri Sep 21, 2018 5:55 pm
Have you changed the RPM DRO to 2451?
Postby merlinogio » Fri Sep 21, 2018 6:09 pm
Thanks ger for your quikly answer..
yes i have yet changed..
an habit very strange because with the spindle talker it go..
flavio
merlinogio
Postby merlinogio » Fri Sep 21, 2018 6:12 pm
i have hy12 and xbox360 as active plugins...
merlinogio
Postby merlinogio » Fri Sep 21, 2018 6:20 pm
and if i use hy10 UCCNC give me message that it can't open com port
merlinogio
Users browsing this forum: No registered users and 26 guests
