Hello everybody,
I recently bought the UB1 and I'm currently busy with the wiring.
I have a Z-axis with a brake: how do I connect it (my old TripleBeast has a separate connector for this)?
Regrads,
Martin
cncdrive wrote:If the brake is to hold the axis when the power goes off, so e.g. the Z-axis will not roll off to the table then you could connect it e.g. on a relay on an enable output from the UCCNC or on the charge pump signal,
so the brake releases when the UCCNC runs or when is not in reset, depending on if you will use an enable or charge pump and how you configuring it.
