Wire all UC300ETH PORT
Postby odino87 » Fri May 30, 2025 1:07 pm
What is the right combination of breakout boards to use all the 5 LPT port?
I was thinking about 2 UCBB and 1 UCSB but I realized that UCSB is not switched to input side...
What the correct way?
odino87
Re: Wire all UC300ETH PORT
Postby cncdrive » Fri May 30, 2025 2:46 pm
You can use 2pcs UCBB, but the remaining port is an input type port, so the UCSB is not compatible.
We will have a single port input type breakout board available soon, it will be called UCIB.
It is not available for sales yet, the first batch is currently being manufactured, so it will likely take a few weeks.
I've attached the preliminary datasheet.
UCIB_manual.pdf
(1.38 MiB) Downloaded 285 times
Postby odino87 » Sun Jun 01, 2025 10:36 am
Wow that's a wonderful news.
Thanks. :D
odino87
