Hello Guys,
I have a AXBB-B and a Vevor 3Kw spindle that are not playing well together.
I am using AO1 to set the speed of the spindle and pin 6 port 1 to switch it on.
I have set the VFD to " see " a 0 -10 volt input and a switch to ground on / off signal.
If I short out the on / off to ground manually, the spindle works, if I run it through a " dry " relay to ground, the spindle runs for < a second, stops and trips the E Stop. the spindle stops.
If I set the Active Low box on the " Spindle relay output enabled " and again command the spindle to run, it does run without stopping, the E Stop button on the screen flashes like it is tripped but the spindle continues to run.
The spindle runs as it is supposed to when controlled by the run / stop buttons on the VFD.
When the E Stop button flashed, no inputs are tripped ( on the diagnostic screen ) just clicking on the button re-sets it.
I swapped the pins to the VFD and mist buttons ( M3 & M7 ) the VFD / Spindle had the same problems with both M3 & M7.
Ed
Thanks for any suggestions.
