AXBB pwm 0-10v
Posted: Thu Sep 19, 2019 11:24 pm
I've searched past threads but haven't found anything detailing this exact issue, so apologies if this has been covered and I missed it.
Running a gecko g540, and decided to ditch the parallel port and switch to an AXBB and UCCNC. Struggling with PWM issues now. Per the manual, I'm using AO1 and 5VO to feed my kblc spindle control board the 0-10v that it needs (this was done via the g540 previously). I'm only getting 2.5v between AO1 and 5VO at full duty cycle. This is proportionate to spindle speed and pwm settings, so that's functioning. The jumper is removed, and all power supplies are isolated and outputting proper voltage. I'm reading 5.0v on the dot on 5V+ (not sure if that matters). Spindle PWM ->analog ch is set to 1, and I've played with different pulley setups. Still only 0-2.5v variable. Any ideas?
I'm just a dumb mechanical engineer - electrons are dark magic to me .
rewster
rewster
