Issues with servoconfig
Postby Derek » Tue May 14, 2019 1:10 am
So I just tried to hook up to one of my drives. Servoconfig recognizes the programing stick when it is plugged in by itself. There is also something else listed that doesn't seem to be anything. It's been a long time since I had to access a drive. I tried a different USB cable but no luck. I tried three different drives on two different machines both running Windows 7.
Is there anything with windows 7 that could be causing this or do you think the stick is dead. I have used the programing stick before but I'm not sure if I had ever used it with either of my windows 7 machines. It has always been finicky about recognizing drives.
Derek
Derek
Re: Issues with servoconfig
Postby Derek » Tue May 14, 2019 11:36 am
Looks like it is loose pins or a poor connection between the programing stick and the drives. I'll keep playing with it to see how it goes.
Derek
