The First Movements = More Questions...
Im very happy with my progress, Im making movements. Everything is homing and Im happy with that so far.
But the questions I am having are as follows :
1) MM vs IN... I'm in the great white north, so I am accustomed to using MM in my drawings and designs. SO.. My UCCNC installation was in MM. Meaning my Units are in MM. I have done the stepper calibrations, and I have not done any changes to the acceleration or velocity settings for each axis. My speeds.. are VERY SLOW. I BELIVE that i need to multiply my velocity and acceleration "Units per min" by 25.4 to convert my mm "Units per min" to match the inch per min equivalent... Am I right?
2) Axis Directions.. My Z Axis and Y/A Axis runs correctly. my X Axis runs counter to my keyboard inputs. Is this a direction pin or steps pin issue?
3) Z Axis 0/Probing (Floating head, NOT THC)... I cannot figure out how to set an offset. Is this the Safe Z setting?
4) SheetCam/MiniTHC ... Im using a MiniTHC along with floating head and Ohmic Sensor. I am also going to continue to use SheetCam as I am familiar with its use due to my previous experience with LinuxCNC/CandCNC. Is there a post that you can recommend for me to start with?
