M6/M31 Macro Pair to emulate Carbide3D Bitzero Probing
Re: M6/M31 Macro Pair to emulate Carbide3D Bitzero Probing
Postby jparkone » Wed Dec 11, 2024 9:28 am
Just downloaded and read through the readme. This is so helpful thank you for all the work you've put into this!
I was wondering if I could use this with a touch probe in edge probing mode. I think I'd need to:
1. set the touch plate lip thicknesses to 1/2 the probe tip diameter. Or set the bit diameter to this and the plate values to zero
2. set the touch plate shelf thickness to zero
I've tested and the touch probe will not trigger when actuating the fixed plate, the fixed plate is much more sensitive. I think if it did, the next tool wcs would be set too high, right?
Does this make sense? I'm a little unsure about the z part of this but its easy enough to just test and see.
I don't have a mobile probe like the Openbuilds or Triqueta but do have a touch probe!
Cheers
Jesse
jparkone
Return to UCCNC TOOL BOX
