Surface Probe Wizard
Postby Vmax549 » Fri Jun 22, 2018 11:56 pm
Here is a simple Probe Surface Wizard. Unzip it into your macro folder. Call it with M9101.
(;-)TP
SurfaceProbe.zip
(23.88 KiB) Downloaded 46 times
Vmax549
Re: Surface Probe Wizard
Postby henkul » Fri Aug 03, 2018 2:49 pm
Hi Vmax549
I have tried the macro and its running and probing at the given points, but I miss getting the probed data in a file.
henkul
Postby cncdrive » Fri Aug 03, 2018 8:39 pm
You have to activate the M40 and then the probed datas will be remembered and with the M41 the datas will be written into file.
Postby henkul » Sat Aug 04, 2018 6:03 pm
The M40 and the M41 was already in the generated Gcode-file. I am running version 1.2042 on a Stepcraft and the 'Probe tab' does not show up. I guess I need to upgrade.
henkul
Postby henkul » Sat Aug 04, 2018 6:30 pm
The Probe tab in the Tools menu show up when I use the default profile. I found the menu parameters in the Stepcraft profile and changed the values, but I only got an empty file.
henkul
Postby Vmax549 » Sat Aug 04, 2018 7:00 pm
I ReTested it here and it produces a Saved file with points values.
I do see a small glitch in teh Gcode creation I will correct.
(;-) TP
Vmax549
Return to UCCNC TOOL BOX
