Please check UC.Readkey function
Postby shad » Sun Nov 05, 2017 7:12 am
Hello Balazs!
Please check UC.Readkey function.
I had situation with empty key value in profile file.
Key was without value:
OxySlideOffset =
When I try to read this key it's return nothing. I was sure ReadKey function return defaul value. For example this function must return "0" string in any case:
string value = UC.Readkey("PlasmaOxyPinMapping", "OxySlideOffset", "0");
Or I am wrong?
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
http://neuroncnc.com/
shad
Re: Please check UC.Readkey function
Postby Dan911 » Sun Nov 05, 2017 9:20 am
Testing I've done with Read/Write key... is Readkey never looks at the value you input and just writes value of key your reading. If that value is empty it will return empty. If you want a default value for a key you need to write it there.
Postby cncdrive » Sun Nov 05, 2017 10:26 am
Hi Andrew,
If the key is defined in the profile file, but the value is empty then the Readkey function will return an empty string.
The Readkey function returns the default value only if the key is not defined.
If you don't allow empty value then simply test the read value for empty string and if it matches then give it a different value or do your exception routine.
Postby shad » Tue Nov 07, 2017 5:29 pm
Hello!
Thank you for explain.
Balazs, please do not forgot about function in the API for turn on moveback on arc lost future independent from the THC ON/OFF state.
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
shad
