Xbox controller, Y+ keeps moving after letting go of button
Postby dhb9mm@gmail.com » Sun Aug 07, 2022 10:52 pm
My Xbox controller when i move any other axis it works fine, but when i move it in Y+ it keeps moving even after I let go of the button. the only way I have found to stop it is for it to hit the over travel sensor, or hit the UCCNC reset button on the screen. any help would be appreciated.
David Branch
dhb9mm@gmail.com
Re: Xbox controller, Y+ keeps moving after letting go of but
Postby eabrust » Mon Aug 08, 2022 1:44 am
Hi David,
Which plugin are you using? Do you have the button release set to fire the +y axis stop (button code 231, JogYplusoff)? Each axis direction has a jog start code and a jog stop code which must be paired up correctly when you set the individual buttons .
Postby dhb9mm@gmail.com » Mon Aug 08, 2022 2:01 am
Here are settings.
dhb9mm@gmail.com
Postby dhb9mm@gmail.com » Mon Aug 08, 2022 2:22 am
I booted my system back up to get you the plugin version. Now without changing anything it is working fine. I don't know what happened unless rebooting helped.
David Branch
dhb9mm@gmail.com
