xhc hb04 handwheel problem
Postby neptunier » Fri Nov 19, 2021 1:14 pm
hello all,
i got a used xhc hb04 usb handwheel today. i enabled the plugin, all the buttons work fine. however turning the handwheel, the table only moves in one direction, no matter if i turn clockwise or counterclockwise.
is this an issue with the plugin or did i got a broken handwheel. i am using version 1.2113 on windows 7, win7 driver is installed correctly.
my x box controller works just fine.
thanks,
michael
neptunier
Re: xhc hb04 handwheel problem
Postby cncdrive » Sat Nov 20, 2021 11:37 am
There is no such problem with the plugin, nobody reported such issue, so it is likely an issue with the pendant.
Maybe get a UCR201. :)
Postby neptunier » Sat Nov 20, 2021 11:38 am
i was contemplating getting the UCR201. thanks for the info.
neptunier
