Huayang vfd problems
Postby Can77 » Wed Jun 26, 2019 6:41 pm
Hi
I'm a newbie and have been trying to get my workbee to run.
I've got an axbb_e motion card and use a rs485 connection for the vfd.
I managed to set the huayang vfd according to the settings below.
Tried the hyplugin 14 without luck, switched to v12 and it worked.
The problem is that a few seconds after I start the spindle the spindle stops. Uccnc displays message limit switch or/and motor reset. Can not wrap my head around it. Am I missing something (probably).
Can77
Re: Huayang vfd problems
Postby ger21 » Wed Jun 26, 2019 10:47 pm
Sounds like noise from the VFD is triggering the limit switch inputs.
Postby Can77 » Fri Jun 28, 2019 12:33 pm
Thanks for the tip.
Disconnected the switches. Worked like a charm!
Will set them to NC and see if it solves it.
Can77
Postby Chrescht » Tue Aug 06, 2019 4:58 am
i am new to UCCNC but i had the same Problem with Mach3 an there i had to rise the debounce time for the switches.
Brgds
Christian
Chrescht
Postby Franck56 » Thu Dec 12, 2019 6:03 pm
Hi all,
i agree with Ger21, it's VFD noise. I had the same problem with mach 3 when i first installed my CNC.
All was working fine until the VFD was running. I solved the problem by putting a ferrite bead (that was lying in the workshop) on the spindle cable, near the VFD.
After that, no more problems ! Cheap and efficient fixx !
As i had another one lying, i've put it near the first, just in case .... :D
Franck
ferrite bead on spindle cable near VFD
Franck56
