Mach3 plugin
Mach3 plugin
Postby Preb1 » Tue Feb 13, 2018 10:39 pm
Hi.
Probably a stupid question but here goes.
Using Mach3 at moment. Want to use my uc400eth with Mach3. Loaded the UCx00 plugin and it says all loaded correctly. Also used the UCxx utility and it recognises the 400eth and I saved the address. However, no blue light on 400eth so not connected. Mach3 opens ok. Can close the reset and all axes move on screen but no output. What am I doing wrong please.
Paul
Preb1
Re: Mach3 plugin
Postby cncdrive » Tue Feb 13, 2018 10:47 pm
If no blue light then no connection to the UC400ETH.
Did you test the connection with the UCxx utility tool?
Does it says connection OK?
The UCxx utility tool recognises the UC400ETH even if your IP settings are wrong.
If the test told you any errors then your IP settings is wrong.
Did you follow the steps and setup your network as described in the UC400ETH manual?
