pupdogg wrote:Hi Dan: thank you for your prompt reply. As per their manual (screenshots attached) I modified PD011 to be 140 (8400RPM), and PD072, PD073 to be 140 and 300 respectively. I also changed the plugin lower limit to 8400, saved the settings/profile and restarted UCCNC with not additional luck. I have already once RESET the VFD to factory settings already prior to trying all of my efforts.
Start CW 01 03 01 01 31 88 (VFD address 01, write control data 03, data length 01. data 01, checksum 31 88)
Start CCW 01 03 01 11 30 44
Stop 01 03 01 08 F1 8E
Set Speed 01 05 02 9C 40 D0 3C (05 is write frequency control data (2 bytes)) 9C 40 Hex = 40000 or 400.00 = 24000rpm
