Separate jog feedrate for each axis
PostPosted: Mon Jun 16, 2025 7:24 am
by CFSAB
Hi
I have added a joystick to control two axes. I have created a macro so I have a deadband in the center. Then, it starts jogging and slowly increases the Jogfeedrate (913) when I move the joystick further out. It works good for one axis a the time, but I can“t move them simultaneously (smoothly with different velocity) since there is only one Jogfeedrate for all axes. Would it be possible to add Jogfeedrate fields for each axis? Or is there another way to do it?
Or have a 0-100% of the set Jogfeedrate for each axis, then it would also be possible to, for example slow down Z jog if you have a quick Z axis and you will reduce the risk to hit someting by mistake.
Best Regards
Mikael Jonsson
