Page 2 of 2
Re: "offline mode" should not change machine coordinates
PostPosted: Mon Jan 01, 2024 11:36 pm
by Vmax549
Once you cam a file to be point of origin at say lower left then that is the only way you can cut that file. Unless you use the program extents to set say upper right to the extents values. But the point of origin will still be lower left.
Just a thought, (;-) TP
PostPosted: Tue Jan 02, 2024 8:20 am
We could add an option to make the controller register the machine coordinates when you turn the offline mode on and write the coordinates back when you turn the offline mode off.
Would this feature help you?
PostPosted: Tue Jan 02, 2024 7:11 pm
by JeCaWo
That would definitely help me. And I hope others too. I believe that approach would address every risk I can see with the offline mode.
PostPosted: Wed Jan 10, 2024 9:54 am
by CFSAB
Hi
JeCaWo, I think you and me try to achieve the same thing, or facing the same problem to locate toolpath over some scrap materials.
Take a look at this idea, maybe something that you would like?
viewtopic.php?f=13&t=4698
Best Regards
Mikael
