Parametric Programming - Math - Ceiling Function
Re: Parametric Programming - Math - Ceiling Function
Postby cncdrive » Fri Dec 03, 2021 8:30 pm
The floor and ceiling was really missing from the functions, I've added both now, it will be in the next release.
Postby cseyler » Mon Dec 27, 2021 10:06 pm
Maybe it is not clear for everyone :
The macro system is based on a runtime compilation for C# code. During the compilation UCCNC has to specific which namespaces it uses for compilation (same as using xxxxxx in your C# code).
But you can still use all .NET components (.Net Framwork 4) by typing the entire namespace
so, you can use the ceiling function by typing
System.Math.Ceiling(value);
cseyler
Postby cncdrive » Tue Dec 28, 2021 2:52 pm
Yes, that is correct, but the request was not for macroing, but for parametering programming.
Parametric programming is not compiled by the .net compiler, but is interpreted by the UCCNC itself from g-code.
