UCR201 - Extension the behavior of AXIS/FRO/SRO
Postby stholl » Fri May 31, 2019 10:55 am
I am very satisfied with the UCR201 and use it very intensively. What disturbs me again and again in the workflow is, that I can only select the axes sequentially via the "AXIS / FRO / SRO" button from top to bottom.
What I miss is the possibility to change the direction of the axis selection.
To solutions come to my mind:
1. pressing a second button that reverses the direction
2. turning the jog while holding down the "AXIS / FRO/ SRO" button. The selection would then be executed by the direction of the jog.
Is there any chance to extend that functionality
stholl
Re: UCR201 - Extension the behavior of AXIS/FRO/SRO
Postby dezsoe » Sat Jun 01, 2019 6:46 am
If you don't use some of the function buttons on the UCR201 then you can set them to call button 220..222 for the X, Y, Z axis selection.
Postby stholl » Mon Jun 03, 2019 5:09 pm
That's a great idea in case you have enough free buttons - my buttons are all assigned with different functions.
This was the reason for the request.
Hope you see a chance to extend...
stholl
