Fullstopp instead of comma
PostPosted: Sun Oct 02, 2022 3:02 pm
by BKG
Someone who knows of a code to check/correct , to . ? is a bit scary to use the wrong type at Z ofsett
Re: Fullstopp instead of comma
PostPosted: Mon Oct 03, 2022 8:50 pm
by dezsoe
You can use both: UCCNC will convert it.
PostPosted: Tue Oct 04, 2022 12:28 am
by BKG
dezsoe wrote:You can use both: UCCNC will convert it.
Not if it is in a Macro, then the Z ofsett is going crasy if "," is used
string stNominal = exec.TextQuestion("To probe from the Spoilboard surface, enter the nominal thickness of the material. Enter '0' or leave blank if probing from the material surface (mm)");
double Nominal = 0;
if(!(stNominal == ""))
Nominal = Convert.ToDouble(stNominal);
PostPosted: Tue Oct 04, 2022 9:55 am
by dezsoe
OK, I see. After you input the string try
stNominal = stNominal.Replace(',', '.');
This will replace the commas with points.
PostPosted: Tue Oct 04, 2022 1:51 pm
by BKG
dezsoe wrote:OK, I see. After you input the string try
Thanks Dezoe, that fixed it :)
