I am very new to UCCNC (Been running for a week and still building my CNC) and i am after some help to change the function of a Macro.
I have an open builds 1500x1500 CNC and i have installed an AMB 1050 Spindle with ATC.
Stepcraft provide you with their ATC Macro as the ATC unit is provided by them but i need to make some changes.
I have relocated the Tool Rack from the rear right to the front right of the CNC as i am going to build an enclosure for it and i wouldn't be able to reach it all the way up the back without climing inside!
The Stepcraft Macro allows for 20mm of movement in the Y Axis for placing and removing the tool from the tool clip which is mounted along the Back on the X Axis. I have installed my tool holder along the Y axis instead so it doesnt take up too much room at the front.
Can someone please point me in the right direction to change this seting so that it allows the 20mm of movement in the X Axis instead of the Y?
I hope my explanation makes sense!
Here is the Current Macro
- Code: Select all
//STEPCRAFT linear toolchanger code
// (1) STEPCRAFT port definition
int Chuckopenport = 2;
int Chuckopenpin = 4;
double[] ToolX = new double[11];
double[] ToolY = new double[11];
ToolX[0] = 0; // Tool0 X position
ToolY[0] = 0; // Tool0 Y position
// (2) STEPCRAFT tool holder XY positions
ToolX[1] = 1228.7; // Tool1 X position
ToolY[1] = 20.5; // Tool1 Y position
ToolX[2] = 1228.7; // Tool2 X position
ToolY[2] = 53.1; // Tool2 Y position
ToolX[3] = 1228.7; // Tool3 X position
ToolY[3] = 86.6; // Tool3 Y position
ToolX[4] = 1228.7; // Tool4 X position
ToolY[4] = 119.9; // Tool4 Y position
ToolX[5] = 1228.7; // Tool5 X position
ToolY[5] = 153.6; // Tool5 Y position
// (3) STEPCRAFT optional tools
ToolX[6] = 1228.7; // Tool6 X position
ToolY[6] = 186.4; // Tool6 Y position
// ToolX[7] = 100; // Tool7 X position
// ToolY[7] = 180; // Tool7 Y position
// ToolX[8] = 100; // Tool8 X position
// ToolY[8] = 180; // Tool8 Y position
// ToolX[9] = 100; // Tool9 X position
// ToolY[9] = 180; // Tool9 Y position
// ToolX[10] = 100; // Tool10 X position
// ToolY[10] = 180; // Tool10 Y position
// (4) STEPCRAFT basic parameters for tool change
double SafeZ = -2;
double Ztoolrelease = -56.8;
double Ztoolpickup = -56.8;
double Ytooloffset = -20; //STEPCRAFT tool position offset for Y
double Ztooloffset = -15; //STEPCRAFT tool position offset for Z
int Newtool = exec.Getnewtool();
int Currenttool = exec.Getcurrenttool();
if(Newtool == -1) // If new tool number is -1 means a missing T code, so we need to stop here...
return;
// (5) STEPCRAFT max. number of tools possible
if(Newtool <0 || Newtool >6) // Tool number is out of range, so we need to stop here...
return;
if(Newtool == Currenttool) // Same tool was selected, so do nothing, stop here...
return;
if(!exec.GetLED(56)||!exec.GetLED(57)||!exec.GetLED(58)) // If machine was not homed then it is unsafe to move in machine coordinates, stop here...
MessageBox.Show("The machine was not yet homed, do homeing before executing a tool change!");
exec.Stop();
return;
while(exec.IsMoving()){}
// Get current XY machine coordinates to return to this position at the end of the macro
double Xoriginalpos = exec.GetXmachpos();
double Yoriginalpos = exec.GetYmachpos();
// Stop spindle if running and Move Z up
exec.Stopspin();
exec.Code("G00 G53 Z"+ SafeZ); // Move Z up
if(Currenttool!=0)
// Move to old tool position on XY plane
// STEPCRAFT
exec.Code("G00 G53 X" + ToolX[Currenttool] + " Y" + (ToolY[Currenttool] +Ytooloffset));
// Drop current tool
exec.Code("G00 G53 Z"+ Ztoolrelease); // Move Z axis down to tool holder position
// STEPCRAFT
exec.Code("G01 F500 G53 Y" + ToolY[Currenttool]); // Move Y axis to tool holder position
exec.Setoutpin(Chuckopenport, Chuckopenpin); // Open the chuck with pneumatic valve
exec.Wait(1000); // Wait one 1000msec
// STEPCRAFT
exec.Code("G01 F500 G53 Z"+ (SafeZ + Ztooloffset)); // STEPCRAFT Move Z up for tool change
if(Currenttool==0)
// STEPCRAFT open chuck if tool = 0
exec.Wait(200);
MessageBox.Show("No tool in chuck. Correct?"); // STEPCRAFT safety question
if(Newtool!=0)
// Move to new tool position on XY plane
exec.Code("G00 G53 X" + ToolX[Newtool] + " Y" + ToolY[Newtool]);
// Pick new tool
exec.Code("G01 F1000 G53 Z"+ Ztoolpickup); // Move Z axis down to tool holder position
exec.Clroutpin(Chuckopenport, Chuckopenpin); // Close the chuck with pneumatic valve
if(!exec.Ismacrostopped()) // If tool change was not interrupted with a stop only then validate new tool number
exec.Setcurrenttool(Newtool); //Set the current tool -> the new tool
//MessageBox.Show("Tool change done."); // STEPCRAFT no message required
// STEPCRAFT
exec.Code("G01 F1000 G53 Y" + (ToolY[Newtool] +Ytooloffset)); // Move Y axis to tool holder offset position
if(Newtool==0)
// Move Z/axis up with open chuck
// Move back to start point
exec.Code("G00 G53 X" + Xoriginalpos + " Y" + Yoriginalpos);
// Measure new tool will go here....
// Getting the tool offset of the new tool
exec.Code("G43 H"+Newtool); // Load new tool offset
exec.Wait(200);
if(exec.Ismacrostopped()) // STEPCRAFT interruption
exec.StopWithDeccel();
MessageBox.Show("Tool change was interrupted by user!");
Chris
