Macro loop input time delay
Postby Mcasey » Wed Nov 03, 2021 4:05 pm
Hi guys,
I am using a collision detect head on a plasma head and the problem I have is that my proximity sensors are too sensitive, if the head barely touches the smallest bit of dross it stops the machine, I want to make a macro loop that will have a time delay of approx 0.5sec before it sends a signal, this will allow the head to have a small amount of movement before it actives the limit. I have been pulling my hair out trying to do this, can anyone shed some light on how to add a time delay to an input.
Mcasey
Re: Macro loop input time delay
Postby dezsoe » Wed Nov 03, 2021 4:19 pm
Do you want to write the macro or just a solution to delay the sensor? If the second then try the Fault signals plugin: it has a delay on the input signal.
Postby Mcasey » Thu Nov 04, 2021 11:14 am
I would like to write it if possible, I'm trying to learn how to write macros, I've done quite a few simple macros just executing g code, but just can't figure this out
Mcasey
Postby dezsoe » Thu Nov 04, 2021 11:55 am
OK, then you need to know some basics.
- Your macroloop code will be executed 20 times per second. (In fact, your code is inserted into a loop which ends with a 50 ms delay.) So, you can have a counter which counts the 50 ms loops: 10 will be a half second.
- To use variables that are not recreated in all loop iterations you have to declare them after the #Events code.
Your macroloop should look like this (in pseudo-code, because you want to write it):
bool inputstate = getled(inputportpin)
if inputstate <> lastinputstate
  // state changed
  if inputstate
    // changed and become active -> reset counter to delay in 50 ms steps
    counter = 10
  // save input state
  lastinputstate = inputstate
if inputstate and counter > 0
  // the input is active and no time-out
  --counter
  if counter = 0
    // timed out
    // do your stuff here
#Events
int counter = 0
bool lastinputstate = false
