#vb
' save file path location w/ existing folder , includes filename in path
dim fname as string = "c:\uccnc2114\test.txt" ' <- change this as necessary
' What you want to write each time you execute macro
dim texttowrite as string
texttowrite = "X" & exec.getxpos & " Y" & exec.getypos & " Z" & exec.getzpos '<- x/y/z pos, w/ leading axis letter
using sw as system.IO.StreamWriter = System.IO.File.appendtext(fname)
sw.writeline(texttowrite) ' <- write to the file, appending line at end.
end using
